Voice port issue
Feb 24th, 2009
Am having a problem with an E1 running from a PABX to a Cisco 2800 voice gateway.
when doing a sh voice por summ, I get the following, not all channels are going into the dormant state, the amount of channels increase/decrease at random, and starts disconnecting calls with a user busy tone:
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
1/0:15 01 isdn-voice up up none none y
1/0:15 02 isdn-voice up dorm none none y
1/0:15 03 isdn-voice up dorm none none y
1/0:15 04 isdn-voice up up none none y
1/0:15 05 isdn-voice up up none none y
1/0:15 06 isdn-voice up up none none y
1/0:15 07 isdn-voice up dorm none none y
1/0:15 08 isdn-voice up dorm none none y
1/0:15 09 isdn-voice up up none none y
1/0:15 10 isdn-voice up dorm none none y
1/0:15 11 isdn-voice up dorm none none y
1/0:15 12 isdn-voice up down none none y
1/0:15 13 isdn-voice up down none none y
1/0:15 14 isdn-voice up down none none y
1/0:15 15 isdn-voice up down none none y
1/0:15 17 isdn-voice up down none none y
1/0:15 18 isdn-voice up down none none y
1/0:15 19 isdn-voice up down none none y
1/0:15 20 isdn-voice up down none none y
1/0:15 21 isdn-voice up down none none y
1/0:15 22 isdn-voice up down none none y
1/0:15 23 isdn-voice up down none none y
1/0:15 24 isdn-voice up down none none y
1/0:15 25 isdn-voice up down none none y
1/0:15 26 isdn-voice up down none none y
1/0:15 27 isdn-voice up down none none y
1/0:15 28 isdn-voice up down none none y
1/0:15 29 isdn-voice up down none none y
1/0:15 30 isdn-voice up down none none y
1/0:15 31 isdn-voice up down none none y
Any ideas why this is happening?
paolo bevilacqua Tue, 02/24/2009 - 00:08
  • Hall of Fame,
    Founding Member
which exact ios are you using ?
if you reload the router, does it behaves correctly for a while ?
shaunswales Tue, 02/24/2009 - 00:35
Version 12.2(11)T2.
Have reloaded and then only 1 or 2 channels are in dormant state and then slowly increments, and then decrements again after a while. We have replaced the card in the router, replaced the cabling, and the card in the PABX, which has made no difference.
Nicholas Matthews Tue, 02/24/2009 - 07:21
  • Red, 2250 points or more
12.2T code is very old. I would put the most recent code that is 1) released for your platform or 2) fits on your flash and see if you get different results.
-nick
shaunswales Tue, 02/24/2009 - 22:27
Thanks Nick, I'll have a look at a later version, log a change and upgrade. However in situations like this when down time is required, we have to provide a valid reason for upgrading, checked the bug toolkit and don't find anything specific to this problem. I'll give it a try and post results here soonest.
