7960 can't register in CME using SIP
Feb 24th, 2009
The phone is in different subnet from the CME
I have tried different combinations of (as I don't know the exact reason for the commands)
authenticate register
authenticate realm
CME 7.0(0)
phone firmware P003-08-6-00
Thanks in advance
Paolo Bevilacqua Tue, 02/24/2009 - 01:50
Hi, before looking at the traces, have you considered using SCCP? That will give you more features and less troubles.
Nicholas Matthews Tue, 02/24/2009 - 07:30
Hi Steven,
The phone should be downloading a configuration file that downloads the password. You shouldn't have to configure anything in the phone, nor any of the authenticate register/realm commands.
Put the password on the phone like you have it, and 'debug tftp events' and make sure the phone is getting the correct file.
steven_chan Tue, 02/24/2009 - 18:32
I do see messages in the forum that you are suggesting SCCP for CME. I think everyone has a reason for the move and mine is "v3"
I see the phone is keep trying to get the config file SIPmacaddress.cnf and can download the file correctly. I verify it by removing the DN on the phone.
Nicholas Matthews Tue, 02/24/2009 - 19:25
Hi Steven,
If you remove all of the extra authentication commands under sip-ua and what have you, and just use the basic commands, this should register. If you're wanting to add other functionality, I would add it on slowly after getting basic things to work first.
Basic requirements:
-voice service voip
registrar server
-phone must download configuration file (Cisco phones)
-if the phone is on a different subnet than the CME source address, it must authenticate with a password
-if you have a SIP bind command, you must have the same source address in CME
-the phone should try to register, get a 401, and send another register with authentication. We should then 200 OK that REGISTER message
-the phone will need the 'type' command and 'id mac' in order to download the configuration file
Hopefully something there is helpful.
mciarfello Thu, 03/26/2009 - 12:21
I think he was referring to CCIE VOICE lab v3, which has SIP endpoints on the map.
