How to config QoS in ASA5550
Feb 24th, 2009
Dear all,
Video & voice is not clear in telepresence device, using ASA between inside & outside. how to configure QoS for this scenario.
thanks & regards,
Syed Iftekhar Ahmed Tue, 02/24/2009 - 01:34
  • Blue, 1500 points or more
ASA's uses QOS only in outbond direction.
It utilizes a single LLQ and matches
DSCP via class maps.
As far as configurations goes, you need to enable LLQ on an interface.Use class map to select traffic that you want to use in Queue and finally push traffic to the queue using policy map.
Following link will give you an example
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008084de0c.shtml
Syed Iftekhar Ahmed
