PRIVILIGE COMMNAD
Feb 24th, 2009
hi all,
i applied following command
"privilege interface level 6 vlan-range"
but not able to c any sub-commands when i reach...
conf t--interface gig x/y--vlan-range--
only "no" is there.
Any clues
Mohamad Qayoom Tue, 02/24/2009 - 10:29
  • Bronze, 100 points or more
What kind of device is are you working on?
sohaildxbfze Tue, 02/24/2009 - 11:23
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5S-M), Version 12.2(25)EWA, RELEASE SOFTWARE (fc1)
Yudong Wu Tue, 02/24/2009 - 11:12
  • Gold, 750 points or more
you might need "all" option to enable all sub-commands when using privilege command.
sohaildxbfze Tue, 02/24/2009 - 11:24
in
all keyword is not acceptable at all in any privilige mode exec/configure/interface
Yudong Wu Tue, 02/24/2009 - 11:49
Yeah, this feature might not be in there.
Is there "priviledge vlan-range"? If not, you have to use AAA to control this.
sohaildxbfze Tue, 02/24/2009 - 13:30
no, but under interface level 15, i can access vlan-range then service-policy, but problem is all commands will be enabled even if i will restrict thru privilige.
Also checked CLI role based views,, but i dun know y my 4501 ios doesnt support that one too i have ip voice services
