ASA IPS, auto update issue
I am having an issue with auto update on the IPS module installed the ASA.
Auto Update Statistics
lastDirectoryReadAttempt = 06:00:34 UTC Wed Feb 23 2009
= Read directory: https://198.133.219.25//cgi-bin/front.x/ida/locator/loca
tor.pl
= Error: AutoUpdate exception: Receive HTTP response failed [3,212]
lastDownloadAttempt = N/A
lastInstallAttempt = N/A
nextAttempt = 06:00:00 UTC Thu Feb 24 2009
I can see from the above that there is a HTTP response error, I have checked and there does not seem to be any other unit stopping the responses. With regards to the ASA config do I need to allow the IPS module though the ACL's or NAT statements?
Many thanks MJ
rhermes Wed, 02/25/2009 - 09:34
Management traffic from the AIP-SSM module will use the module's management ethernet interface. To answer your question, it depends on what network (or firewall interface) you have the AIP-SSM Management interface connected to.
