WCS Alarm Mail Spam after Upgrade to 5.2 on WLCs
Feb 24th, 2009
iam running a WCS 5.2 with some WLCs on 5.2. Since i have upgrade them to 5.2 the WCS Email-Alarm-Notification spams my mailbox with the following informations :
{wlcname} AP 'apname', interface '802.11b/g/n' is up on Controller 'ip-adress'.
{wlcname} AP 'apname', interface '802.11b/g/n' is down on Controller 'ip-adress'.
The crazy thing is that the mail relay first posts the up message and then the down message so there is maybe 1 Second downtime. (the mails are coming in the same second)
If i check all the logs of the wlcs i can't see any dissassociation of an accesspoint or any problem that causes the wlc to send a trap or write a syslog. So i have sniffed the Wcs snmp communication and i can see that the wcs polls in the same time the wlc but there is only about 3-4 ms duration time between the request and response so the reason for that "mail-spam" is hard to find for me..
Do you have any ideas where i can see the reason for that problem ? Is there any timer on the wcs for generating this alarms ?
Otherwise i have to contact the TAC support.
Thanks for ideas, Dennis
Leo Laohoo Tue, 03/03/2009 - 21:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Go to the WLC, Management -> SNMP -> Trap Controls -> AP Tab and then un-tick "AP Interface Up/Down".
Hope this helps.
dneckermann Wed, 03/11/2009 - 00:32
Hi, this wont solve the problem. This is only a workaround to disable the messages.
wmblake755 Thu, 03/19/2009 - 07:12
Having the same problem with 5.2, anyone else see this? Also, which alarm category does this belong to in WCS?
heiko.bachofner Thu, 07/09/2009 - 23:49
Hi Dennis,
a customer of us have the same problem.
Did you get any answer,yet or do you opened a TAC Case ?
Best regrads
Heiko
dneckermann Mon, 07/13/2009 - 21:26
we have no answer about this problem. After an upgrade to 6.0 there is no problem anymore.
Regards Dennis
tdhb..hiq Sun, 08/08/2010 - 16:38
I am having similar problems, but we have version 6.
Whenever a AP changes channels, to reduce noise or interference, I recieve alarms stating as below;
802.11b/g/n interface of AP THA-A-AP-04 is down: Controller 10.218.100.251 Reason: Unknown.
802.11b/g/n interface of AP THA-A-AP-04 is up: Controller 10.218.100.251 Reason: Unknown.
Is there a way to reduce these messages or mitigate them? I still want to know if the AP goes down, but not every time there is a change in channel.
thanks
WCS Version  6.0.196.0
WLC Software Version 6.0.182.
Trending Topics - Security & Network
