02-24-2009 03:04 AM - edited 03-14-2019 03:43 AM
Hi All;
I have two skill groups (A and B), and there is a dedicated agents for A and a shared agents between B and A (same agents in B are existed also in A also). How can I let the calls that come to skill group A to go first for the agents dedicated for the skill group A and if there is none of these dedicated agents for A are available then to go for the shared agents which are existed in A and B?
I need to do this because I am considering the dedicated agents for skill group A are more expert than those are in skill group B (who are also shared between B and A), so I need calls to go firstly for the expert agents (the dedicated for A) and if all experts are busy, then to use the shared (those who are shared between A and B).
Any advise?
Bilal
Solved! Go to Solution.
02-24-2009 05:25 AM
Simple, remove the agents from A that are in B and leave then in B. Next, when you queue use the consider if field of the queue to skill group node. Queue A first and only queue B if there are no agents available in A.
david
02-24-2009 05:25 AM
david
02-24-2009 05:36 AM
Very thanks.
And if A and B all are busy, a call came to be sent for B and later another call came to be sent for A, both of these calls will go to the queue as no agents free in A and B skill groups. If an agent from B become free, then I need the call A that is in the queue to be sent for this agent in the B skill group which just become free and keep the call B in the queue until another agent become free while no call B in queue any more.
How can this be acheived in addition to previous senario?
Your kindly help is high appreciated.
Bilal
02-24-2009 05:44 AM
You will need two queue to skill group nodes. The first one is for A, which queues A and queues B if no one is available in A with a priority of 4.
The second queue to skill group node queues only B with a priority of 5.
david
