WAAS - Major error (secured_client_detected )
Answered Question
Feb 24th, 2009
sel
branch#test s
branch#test self-diagnostic all
running test `basic'
running test `connectivity'
running test `interfaces'
running test `tfo'
running test `wccp'
running test `inline'
running test `system'
running test `wafs'
Diagnostic Report performed on 2/24/2009 14:5:56
Test NOTE [basic]
NOTE NO_NTP_CFG Device ntp time synchronization is not configured
Action:
Use 'ntp server' cli command to configure NTP server.
Test PASS [connectivity]
Test NOTE [interfaces]
NOTE IFACE_DOWN Interface GigabitEthernet 2/0 is not up
Action:
Use 'interface type slot/group' cli command followed by 'no shutdown' to enable the interface.
Test PASS [tfo]
Test NONE [wccp]
NONE - Skipping test because WCCP is not enabled
Test WARN [inline]
WARN INLINE_SHUTDOWN Inline group 1/1 interface is in bypass mode(shutdown)
Action:
Use 'interface inlineGroup slot/group' cli command followed by 'no shutdown' to enable the interface.
Test WARN [system]
WARN HAS_ALARM 1 Major Alarms are raised in the device. Please find the list below.
1. secured_client_detected
Action:
Critical/major alarms are raised. Check device alarms using 'show alarms detail' cli command for details.
Test NONE [wafs]
NONE - Skipping test because Wafs is not enabled
branch#show
branch#show al
branch#show alarms dew
branch#show alarms detail
Critical Alarms:
None
Major Alarms:
Alarm ID Module/Submodule Instance
1 secured_client MAPI_AO MAPI Instance
Feb 24 13:33:32.230 UTC, Communication Alarm, #000003, 23000:23001
Can anyone help what does this error stand for? and how can i remove it?
Correct Answer by dstolt about 8 years 1 month ago
This alarm means that there is an outlook client that is using encryption to communicate with the exchange server. So it's definitely not a major alarm to be too worried about.
In version 4.1.1c, this alarm was removed from Major Alarms and moved to only be logged in the syslog. This was logged under CSCsv31679 resolved in 4.1.1c.
Dan
Overall Rating: 5 (1 ratings)
Correct Answer
dstolt Tue, 02/24/2009 - 08:40
  • Cisco Employee,
Dan
jorjes1984 Tue, 02/24/2009 - 09:21
HEy thanks for your help
I'v got another problem
I keep having the following message regarding the WAFS:
Test NONE [wafs]
How can i enable it?
I have the enterprise license on both Application accelerator WAE's
