Call Manager - Downloading a file from TFTP via CLI
Feb 24th, 2009
I'm trying to download the file Ringlist.xml but it doesnt accept the directory in the msft server. Here is the logs;
admin:file get tftp Ringlist.xml
Please wait while the system is gathering files info ...done.
Sub-directories were not traversed.
Number of files affected: 1
Total size in Bytes: 2241
Total size in Kbytes: 2.1884766
Would you like to proceed [y/n]? y
SFTP server IP: 10.10.10.10
SFTP server port [22]: 22
User ID: admin
Password: *****
Download directory: \
Invalid download directory specified.
How can I download the file what should I write to the directory ?
thanks
Overall Rating: 0 (2 ratings)
christianluven Tue, 02/24/2009 - 08:01
Maybe try a forwardslash for directorydefinition
Download directory: /
Christian
CSCO11796258 Tue, 08/09/2011 - 08:25
I ahve tried the Forward Slash but the same problem
Please  get back me if you know the solution.
Jonathan Schulenberg Tue, 08/09/2011 - 16:11
  • Cisco Designated VIP,
    2017 IP Telephony
Are you on CUCM 6.x? I seem to recall a bug about this although I can't find it at the moment.
The easiest method I can think of is to use a TFTP client such as tftpd32 and just download the file directly from the TFTP server as if you were a phone. Going through the CLI doesn't get you anything in this case.
Martin Busch Fri, 10/24/2014 - 04:27
Hello Jonathan,
how do I do this with tftpd32? Could you please describe what to do in tftpd32?
thanks in advance.
regards,
Martin
Aman Soi Fri, 10/24/2014 - 04:48
  • Purple, 4500 points or more
    2017 IP Telephony
Hi Martin,
instead of using tftpd32, u can use sftp
from CLI of server, run command file list tftp * [this would show all files] or if u know the specific filename run command file list tftp APP8945
now u run the command
file get tftp APP8945 and press enter. Also , at background run freeftpd sofware.enter IP address of PC on which sftp is running.
regds,
aman
