UC500 and VPN
Feb 24th, 2009
I have to make a VPN connection with another site and they have these requirements
Encryption AES-256
Hashing SHA-1
Diffie Hellman Support Group5
Preshard Key
Is this possible with an UC500.
Other site is using a cisci 2811 router
Thx
Filip
fedecotof Tue, 02/24/2009 - 10:38
I'm not an expert but it seems that the UC500 can only be an Easy VPN Server.
This means that you can only have remote VPN client connections to it, or you can also have a remote 2811 acting as an Easy VPN Client. Keep in mind that the UC500 can handle up to 10 tunnels.
Hope this helps.
Ivan Martinon Tue, 02/24/2009 - 11:58
  • Cisco Employee,
Your UC500 supports up to 10 VPN sessions, either remote Access or Site to site, you should not have a problem with the setup, you might however check whether the built in VPN module supports your required setup. How to check? simply entering the lines of the config will error you with a not supported hardware something..
