sbraychuk Tue, 02/24/2009 - 05:42
You must create route pattern and set action to block this pattern.
born2winu2 Tue, 02/24/2009 - 05:57
I have created 1 route pattern which I have set option : 'route this pattern' and 1 partition for all, but not getting idea for blocking.
Thx n Warm Regards
sbraychuk Tue, 02/24/2009 - 06:03
You can create pattern, for example:
Pattern: "810!"
Partition: "InternationalPT"
Route Option: "Block this pattern" and choose "error code".
Do you have Route Option?
born2winu2 Tue, 02/24/2009 - 06:10
Yes I have route option.
I will try this n will let you know in a day or 2.
Thx
