CCX7 server keeps rebooting
Feb 24th, 2009
I recently installed CCX 7.I noticed this morning that the primary server keeps rebooting,thought the HA is stable and fine.
I've never seen anything like this before...has anyone met such a problem and how was it fixed?
Sleen
esa786_2 Tue, 02/24/2009 - 19:28
I have come across some docs, pls read below,
From all research I have found, the node manager will reboot if there is a problem connecting to the database (DC directory), Please verify that it is installed and ok. You should not have a red x across the sql icon. This was the first install, correct? Please verify that the sql is functioning and that all passwords entered were correct per any requirements you have or corperate standards you may be using. Bottom line though, if the IPCCE cant talk to the SLQ, then the node manager can reboot. If you could make those verifications, that would be great,
Thank you
esa
