design needed
Feb 24th, 2009
hi, there.
We have a remote site which has around 10 isolated tiny buildings, one of them has SM optical fiber back to backbone 5km away.
there is NO any physical structure to inter-connect those tiny building together, no copper, no optical fibre whatsoever, and each building would require just <5 IP & Voice connections, so what would be the cost effective and technology-proof solution? thanks.
our last resort is to lay optical fiber which would be very expensive.
dennischolmes Mon, 03/02/2009 - 20:04
  • Gold, 750 points or more
You actually have several options. 1300 series and 1400 series bridges in point to multipoint mode or 1520 series MESH APs with a point to multipoint configuration and ethernet bridging turned on. If all you need is bridging then I would suggest the 1400 series. If you need outdoor coverage as well I would suggest the 1520 solution.
Leo Laohoo Mon, 03/02/2009 - 20:23
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
