Warning message
PPTP from inside
Feb 24th, 2009
Hi. I am having problems starting a PPTP tunnel to an external client from the inside. If I move the pc to the outside, it works perfectly, so I know the far end is configured right.
I am attaching the ASA config, I just dont see anything obvious. The address of the PC that initiates the tunnel is 172.16.0.20 / NATed 12.152.59.237.
Thank you for any tips.
Bob
acomiskey Tue, 02/24/2009 - 07:41
  • Green, 3000 points or more
Add..
policy-map global_policy
class inspection_default
inspect pptp
mx Tue, 02/24/2009 - 11:13
Thank you, I will try this.
I guess I was approaching it wrong, I was looking for rules that denied it.
bob
