WebVPN ssh-plugin doesn't work
Feb 24th, 2009
hello,
i've installed the ssh-Plugin ssh-plugin.080430.jar into our Cisco ASA 5510 Software 8.0(4).
I've created an Entry in the Webtype ACL list and in the Bookmark List. When i connect to the ssl-VPN, i can start the ssh-Java-Aplett and enter username and Password. But then happens nothing. It says "Connected to 192.168,0.5 ssh" "online" the console-window stays black. I've started tcpdump on the ssh-server and it sees no packet on the ssh-port. Is there anything else i have to configure to get this work?
thanks for your answers.
seibertmedia Tue, 02/24/2009 - 08:41
Ok, I've found the solution:
At the acl-list, i can't use the url filter, i have filter on host and service:
Host: 192.168.0.5
Service: ssh
now it works. But other than documented by cisco, it only works with ssh protocol Version 2.
saifuddin.miyaji Tue, 09/27/2011 - 03:19
Hi Seibertmedia,
Could you please explain your solution with commands? We have got the same issue now with ASA 8.4.
saif
