02-24-2009 07:32 AM - edited 03-06-2019 04:12 AM
Is the V2 just the second generation SPA, or does the V2 fit in one environment, while the non-V2 works in another? Can I use the same SFPs in both versions?
Solved! Go to Solution.
02-24-2009 08:36 AM
I believe it's an omission within that portion of the document.
If you read the beginning of the V2 document, it says:
Cisco I-Flex enhances speed-to-service revenue and provides a rich set of quality of service (QoS) features for premium service delivery while effectively reducing the overall cost of ownership.
__
Edison.
02-24-2009 07:59 AM
V2 provides the RJ45 interface as well as other goodies. Best to check the data sheet on V2 and compare with previous model:
V2:
http://www.cisco.com/en/US/prod/collateral/modules/ps6267/product_data_sheet0900aecd804d884d.html
Old Model:
http://www.cisco.com/en/US/prod/collateral/modules/ps6267/product_data_sheet0900aecd80351ee0.html
One thing to keep in mind is that V2 needs SXI on the 6500, per Release Notes:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html
SFPs are compatible on both versions.
HTH,
__
Edison.
02-24-2009 08:18 AM
One thing I noticed when I read the data sheets, is that the non-V2 specifically states under Features and Functions that it supports QoS:
⢠Ethernet over Multiprotocol Label Switching (EoMPLS)
⢠QoS
⢠Hot Standby Router Protocol (HSRP)
⢠Virtual Router Redundancy Protocol (VRRP)
But the V2 data sheet omits support for QoS, and HSRP/VRRP for that matter.
Do you think that is the case - that V2 really doesn't support QoS, HSRP and VRRP?
02-24-2009 08:36 AM
__
Edison.
