Phone Proxy and MOH Failure
routerguy666
We have been testing out the ASA UC Proxy functionality. It was fairly straight forward to configure, and we have a working setup now with one exception - when placed on hold, the off site phone does not receive music on hold.
When the call is placed on hold, the CM starts pumping out udp packets containing the MOH and destined for the Media Termination Address configured on the ASA. These packets hit the firewall and are promptly dropped.
Feb 24 2009 14:03:41: %ASA-7-710005: UDP request discarded from prodcm-be/26760 to inside:67.155.4.204/23394
A look at the ASP information shows
TEST-UCPROXY-ASA# sh asp drop frame
Flow is denied by configured rule (acl-drop) 358
And a packet-tracer
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
MAC Access list
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 67.155.4.204 255.255.255.255 identity
Phase: 5
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Finally, taking a look at the phone-proxy session info during an active call:
UCPROXY-ASA# sh phone-proxy media-sessions
3 in use, 5 most used
Media-session: 67.155.4.204/23920 :: client ip 192.168.221.71/29412
Lcl SRTP conn 67.155.4.204/23920 to 71.194.132.108/58919 tx_pkts 221 rx_pkts 222
Media-session: 67.155.4.204/20442 :: client ip 71.194.132.108/58919
Lcl RTP conn 67.155.4.204/20442 to 192.168.221.71/29412 tx_pkts 222 rx_pkts 221
Media-session: 67.155.4.204/30620 :: client ip 71.194.132.108/58918
Lcl RTP conn 67.155.4.204/30620 to 192.168.221.71/22856 tx_pkts 592 rx_pkts 594
And again when the call is placed on hold:
2 in use, 5 most used
Media-session: 67.155.4.204/18176 :: client ip 71.194.132.108/0
Lcl RTP conn 67.155.4.204/18176 to 0.0.0.0/0 tx_pkts 0 rx_pkts 0
In both cases, .221.71 is the office phone, .132.108 is the remote phone. When on hold, the office side goes all 0's.
I am guessing that the issue here is the ASA not accepting an unsolicited udp flow from the Call Manager, but was wondering if anyone else has run into this or if it indicates a configuration issue or... ?
ASA is on 8.0.4, CM is v6, phone is a 7960. CM is configured to send the MOH as unicast, not multicast.
Again, all other aspects of this solution are working as expected. It is only music on hold which fails.
Tommer Catlin
I think this is a limitation of phone proxy and you will not be able to send this to the remote device. I was trying to find a document of support Phone features with PhoneProxy, but I cant seem to find it. I'll keep looking.
dnelson
I'm having the exact same problem with ASA Phone proxy as you are.  Did you ever get resolution on this?
If so could you please post what was done to fix.
I'm using ASA 8.32 / ASDM 6.32 code and CUCM 7.13.
Dave
