Partial config download on ASA 5520
Answered Question
Feb 24th, 2009
Has anyone run across this problem? I'm getting a partial config download on an ASA 5520. We are using SSH and SNMP. The config should be about 300 lines, but only downloads about 100. It seems the # of lines is fixed also. If I add a couple lines at the top of the config, the total # of lines downloaded stays the same. We have other ASAs that are downloading fine. The only difference is we're using telnet on those instead of SSH. Very weird. Any ideas? RME version 4.1.1 on Windows LMS 3.0.1. Thanks.
Correct Answer by Joe Clarke about 8 years 5 months ago
This is most likely my bug CSCsm71678. A patch is available for RME 4.1.1 by contacting the TAC.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 02/24/2009 - 10:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
tim.banic Tue, 02/24/2009 - 10:52
Thanks jclarke. I tried searching the forum before posting but I guess I didn't use the right keywords.
