Expired IIS Certificate in Unity
Feb 24th, 2009
We have a Cisco Call Manager 6.1 system with a separate Cisco Unity 5.0 Build 5.0(1) server. The entire system was put in by a consultant.
The Administration web site uses a self signed cert. Apparently the consultant installed Cert Auth on the Unity box, and issued a cert. Well that cert has expired but other than the constant nag message logging into the Admin site, no problems.
Can I just go into IIS on Unity, create a request from the Default website and renew the cert from either the CA on the Unity box or my own Enterprise CA on my domain controller?
Looking at: Setting Up the Cisco PCA to Use SSL by Using a Certificate Authority from Installation Guide for Cisco Unity it seems pretty straightforward.
We're not using PCA sites but it could be installed. Are there any other caveats here?
Thanks in advance for any guidance
