Whats the difference between wireless gain, power settings?
Feb 24th, 2009
I'm trying to maximize antenna coverage on some APs, and having trouble understanding the differences in the settings.
The settings I'm messing with are:
interface dot11radio0
antenna gain 128
power local cck 1
power local ofdm 1
What do each of these settings do specifically?
Appreciate it, going to try to look up each command to try to understand, but if someone could explain it in real-world terms, I'd appreciate.
Thanks!
Scott Fella Tue, 02/24/2009 - 15:00
The antenna gain command does not impact the radio setting at all and is used for information by the WLSE if you have one.
Here is a link that explains the antenna gain:
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_4_JA/command/reference/cr34main.html#wp2448409
The power local command specifies what power setting you wish to use, 1 being the lowest mW setting:
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_4_JA/command/reference/cr34main.html#wp2459939
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
