startup-config file open failed (Device or resource busy)
Feb 24th, 2009
I've encountered this problem while type command to copy running-config startup-config. The system is OSR-7609 with Sup720, running IOS version 12.2(18)SXF11. How to resolve this problem ?
b.julin Tue, 02/24/2009 - 09:36
Maybe you are bypassing the nvram startup config file and have a very large config file that won't fit in nvram?
Take a look at "show boot" output. and also dir nvram: and see if you have clutter taking up space in there.
hxhsu Wed, 02/25/2009 - 07:07
After erase startup-config in nvram,
then copy running-config startup-config ok, thanks.
