Two ssids attached to one vlan
Feb 24th, 2009
Hi guys!
I have created a second Ssid attached to one vlan. the security parameters are the same on each one.
The devices associated to the first Ssid, the broadcasted one, works fine.
But those who are associated to the second one, the hidden one, have got some problems: the speed of the link decreases so much.
Is this a normal behaviour?
The client wanted to be configured in the way it is.
Thanks in advance
George Stefanick Tue, 02/24/2009 - 10:01
How have you determined the link of the hidden ssid? What is the PHY rates? Are you using the same type of clients on bith ssids?
uosambela Wed, 02/25/2009 - 01:25
Hi friend!
That's the scenario:
This client has some Intermec Handheld reader and iniatially, with just one ssid (wpa2-psk aes), they were working correctly. Then I created a second one to migrate the handhelds from one to another profile gradually, (wpa2-psk aes).
They are working on 802.11g so fine.
I gave the client the new profile credentials (wpa2psk aes) and told him to remove the old credentials from the handhelds and create the new ones, so he can associate to the new ssid while other handhelds keep associated with old credentials.
Some handhelds has just the old profile and others the new one.
Hope it helps.
thank you very much.
uosambela Wed, 02/25/2009 - 06:13
Hi gstefanick!
I'm sorry for the misunderstood.
The SSIDs are diferent.
Security is the same for each SSID:
WPA2-psk aes cipher.
George Stefanick Wed, 02/25/2009 - 10:52
Can you touch on how you determined there is a issue with bandwidth between the two?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
