How to add new subnets to VPN group
fedecotof Tue, 02/24/2009 - 09:52
Do you mean that you have a pool of addresses being given to the VPN clients on the ASA and now you want to add more pools with different address ranges? Or maybe I'm not understanding what you're trying to do, please explain. Thank you.
fedecotof Tue, 02/24/2009 - 10:02
To allow the VPN clients to access the internal subnets you need two things:
1. The internal subnets should be in the split tunnel ACL (if you're using Split tunneling).
2. The internal subnets should be in the nat0 statement for the VPN traffic.
Check that you have those statements correct and if the problem persists, perhaps you can share part of the config...
