HWIC-4SHDSL
Feb 24th, 2009
i have a question in this, as mentioned in the configuration guide for this HWIC , what is the meaning of : The number of routed interfaces for both the HWIC-4SHDSL and HWIC-2SHDSL is two.
Overall Rating: 1 (2 ratings)
Paolo Bevilacqua Tue, 02/24/2009 - 11:13
You can split the interface in two DSL groups. So you can have multiple links between two routers, or a router connected to two more each one using one half.
a_mohammedy Wed, 02/25/2009 - 02:45
what about the 4 port RJ-11 that this HWIC can made, what i know is this HWIC can make one RJ-54 to 4 RJ-11 each can make a connection to a router, is that true?
a_mohammedy Thu, 02/26/2009 - 05:40
i know that the connector is RJ-45 but what i mean is if the HWIC-4SHDSL can provide only two routed connection so the HWIC-2SHDSL can do this also so what is the difference between both of them
Paolo Bevilacqua Fri, 02/27/2009 - 14:24
I see that I've been rated "1" unfairly and without an explanation.
The person that left it should seriously review his attitude toward professionals, and the true reason of frustration when dealing with cisco matters.
