CME 4.0 ad-hoc conferencing and meetme capabilities
Feb 24th, 2009
I have a Cisco 2851 ISR with 1 PVDM2-48 running IOS v12.4(9)T7 Release software (fc3) and CME 4.0. I would like to be able to enable conference bridging and meetme conference with more than 3 people. Is that possible with what I have currently? Can I utilize the PVDM2-48 alone or do I need another module? Or would I need to upgrade my IOS and CME version to 4.1 before this can be done? Can someone please inform me what would be required to do this? Thank you.
Overall Rating: 5 (1 ratings)
roseeng69 Tue, 02/24/2009 - 11:02
Thanks for your response and link. So I guess that means I would have to upgrade my IOS to 12.4(15)T before I can upgrade to CME 4.1. Is that correct? Do you see any problems with me upgrading with my current hardware configuration? Thanks again!
paolo bevilacqua Tue, 02/24/2009 - 11:09
  • Hall of Fame,
    Founding Member
Check the feature history at beginning of admin guide to see if there is any feature that you want to get with 7.0 or 7.1 for example. Then just upgrade IOS image and GUI files if you use it. It is not necessary to upgrade any other file.
Please remember to rate useful posts.
