EIGRP stub and DSCP
Feb 24th, 2009
1. ''EIGRP stub connected.''
Does this command prevent the router from been a transit router. What about other traffic destined to the router,will they be prevented.
2. does NTP relationship use hello and hold time? How is it altered?
3.why is MHSRP preferred to GLBP for load balancing and fail over.
4.(config-pmap-c)set ip dscp EF
(config-pmap-c)set dscp EF
What the difference in the above two commands.
Giuseppe Larosa Tue, 02/24/2009 - 11:38
Hello Just,
1) EIGRP stuub connected makes the router a leaf in EIGRP topology it cannot propagate EIGRP routes by other routers but just its own connected subnets.
There shouldn't be any side effect on other type of traffic including management traffic like NTP
2) NTP should use a single message format
and it is not a logic like a routing protocol but more client/server.
3) I think GLBP can be preferred to having multiple HSRP groups on the same Vlan.
4) the first command applies only to IPv4
the second command can mark both IPv4 and IPv6 packets
Hope to help
Just Kennie Tue, 02/24/2009 - 13:55
I understand and appreciate, but as regards No. 3,what I am asking is the major difference because they look alike to me. I know MHSRP support tracking. thus GLBP too?
Jon Marshall Tue, 02/24/2009 - 13:58
GLBP = automatic load-balancing in the sense that with the clients you simply set up the same default-gateway for all clients in that subnet.
MHSRP is not as flexible. With this setup you need to make sure half the clients use one default-gateway and the other half of the clients use the other default-gateway.
If you are looking to load-balance rather than just have a redundant gateway i would suggest using GLBP not MHSRP.
Giuseppe Larosa Wed, 02/25/2009 - 11:12
Hello Just,
GLBP supports tracking options with object tracking
with GLBP you have a two dimensions "priority"
tracking allows to decide who takes the role as primary forwarder for each AVF (Active Virtual Forwarder)
the GLBP priority is used instead to elect the AVG (Active Virtual Gateway).
Client ARP requests are answered by AVG providing alternate AVF MAC addresses using a load balancing algorithm (default should be round-robin other options are possible)
Hope to help
