LAN Problem
Feb 24th, 2009
Hello experts i have a CISCO old series router of 2500 series the problem which i am facing that this router have no LAN port by default and also do not provide support for modules so please tell me how can i attach my LAN to this router. router has 2 serial ports AUX port and a console port please help me. thanks
Waiting for reply
Best Regards
Ahmad Ellahi
pkurdziel Tue, 02/24/2009 - 19:53
You can not.
The best you can do is connect one of the serials to another router with a lan port.
ohassairi Tue, 02/24/2009 - 23:43
  • Silver, 250 points or more
it's stange to find a router without a lan interface.
has it an AUI port? this a lan interface.
if yes, then you can buy a converter AUI/RJ45
sudhendutaklikar Wed, 02/25/2009 - 02:27
you do one thing u buy a transreceiver which convert serial interface to RJ45 Female connector using this you can connect 1 Lan connection to your router
regard
sudhendu taklikar
system admin
