Route-map
danny.carroll
I am trying to determine if you are able to block a route with a route-map.
I know i can block route through a distribute list. I can also block redistributing with a route map but can i make a route-map act as a distribute list and drop packets from 1 eigrp router to another?
I've been trying in a lab all morning and it doesn't seem to work.
route-map deny_172 deny 10
match ip address 1
interface fa0/0
ip policy route-map deny_172
access-list 1 permit 172.16.0.0 0.0.0.255
thanks
dan
15 Replies 15
Mohamad Qayoom
Level 3
Level 3
What if you do the following :
route-map deny_172 permit 10
match ip address 1
interface fa0/0
access-list 1 deny 172.16.0.0 0.0.0.255
no sorry mate. Didn't work.
maybe i have to do the route map on the router distributing the routes. Is that my problem?
adamclarkuk_2
Level 4
Level 4
Are you talking about blocking 'access' from that network range or stopping that network from entering the eigrp RIB.
If you are talking about blocking access from that network range and you want to do this via a policy route (ip policy) and not a standard ACL, then try the following :-
match ip address 1
set interface Null0
This will pass any trafffic from your ACL to the NULL0 interface therefore blackholing it.
That is if you want to deny access otherwise you have answered your own question by added the route-map to the redistribute line under router eigrp x.
So if the network was a static
redistribute static route-map deny_172
dont forget to add a permit ip any to your ACL otherwise EVERYTHING will be blocked
access-list 1 permit any
yah route maps seem to work just fine for redistributing but internal to the eigrp doesn't seem to work for me.
Maybe that's not even a feature.
What do you mean by internal to eigrp ?
sorry i mean. I mean am not doing any redistributing.
Then I am not sure what you are trying to do, are you trying to filter that network range that is coming in from other eigrp neighbors ??
I have 2 routers both running eigrp.
router 1 has:
172.16.0.1 on fa0/1
10.0.0.1 on fa0/0
router 2 has
10.0.0.2 on fa0/0
I want to block the 172.16.0.x network from being shared by eigrp.
I know i can use a distribute-list to deny the 172.16.0.0 network to the other device. Although I haven't been able to drop the network with just a route-map.
Ah ok
You can use a distribute-list WITH a route-map attached :-
match ip address 1
redistribute eigrp route-map deny_172 in
or
redistribute eigrp route-map deny_172 out
depnding or which router
unfortunately you can't redistribute eigrp into eigrp. It says not allowed :)
Sorry I cut and paste by mistake
distribute-list route-map deny_172 in
or
distribute-list route-map deny_172 out
hmmm. Would you say that this isn't possible without a distribute-list then.
My test was to block it without a distribute list but it doesn't seem to work.
I dont see how else you could do this, have you heard somewhere that you can then?
