daemon manager cannot bind to the specified port:42340
Feb 24th, 2009
  • Gold, 750 points or more
The port 42340 is unoccupied according to lsof or netstat -n. There was a NetConfig job that was hanging (probably due to CSCsv95235/CSCsw39641/CSCsw88378) that I had to "kill -9" on after dmgtd stop.
tail dmgtd.log
Feb 24 15:22:27 nms dmgt[15869]: [ID 663561 local0.warning] #2067:TYPE=WARNING:System Error: The daemon man
ager cannot bind to the specified port:42340 because the port is in use by some other application. Call your tec
hnical support representative for assistance.
Feb 24 15:22:27 nms dmgt[15869]: [ID 658247 local0.warning] #2009:TYPE=WARNING:System Error: The Daemon Man
ger cannot bind to port:42340 System Error: The daemon manager cannot bind to the specified port:42340 because t
he port is in use by some other application. Call your technical support representative for assistance.. The TC
P port:42340 that the Daemon manager expects to use is not available. Call your technical support representative
for assistance.
Feb 24 15:22:43 nms dmgt[15902]: [ID 663561 local0.warning] #2067:TYPE=WARNING:System Error: The daemon man
Feb 24 15:22:43 nms dmgt[15902]: [ID 658247 local0.warning] #2009:TYPE=WARNING:System Error: The Daemon Man
for assistance.
less daemons.log
ERROR: open file dmgtd failedThe TCP port that Daemon Mgr expects to use is not available
yjdabear Tue, 02/24/2009 - 12:56
Never mind. Solved it by running "/opt/CSCOpx/bin/perl /opt/CSCOpx/bin/dbstop.pl all".
