TACACS not working in ASA 8.0(3)
Feb 24th, 2009
We have quite a few ASA s with similar tacacs and crypto configs but yesterday we had issue with pix and we swapped pix with ASA 8.0(3) and tunnel is up and running but we are not able to login using tacacs even after the configs,, and i found a bug in cisco.com which asks us to use command " crypto map set reverse-route"
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsk08454
even after configuring it right,, am not able to,, login using tacacs,, can some tell me how to use this command or ,, any other way ?
thnx in advance
Overall Rating: 5 (1 ratings)
ansalaza Tue, 02/24/2009 - 13:09
  • Cisco Employee,
Ok so Local Device was swapped from PIX to ASA. What is the remote Device?
Could you show us the configs from both Ends of the tunnel?
dbellamkonda Tue, 02/24/2009 - 13:40
we have a tunnel established with remote ASA and here are the configs related: let me know if ya need any hing,, thnx for replyin thgh
local device configs:
aaa-server protocol tacacs+
aaa-server host < ip>
aaa authentication ssh console
aaa authentication http console
access-list extended permit ip any
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto map 20 match address
crypto map 20 set peer x.x.x.x
crypto map 20 set transform-set ESP-3DES-MD5
crypto map 20 set reverse-route
crypto map interface outside
crypto isakmp enable outside
crypto isakmp policy 20
crypto isakmp policy 65535
remote ASA
access-list remark MobileAL
access-list extended permit ip any ip add subnet
crypto map 1925 match address outside_1925_cryptomap
crypto map 1925 set peer
crypto map 1925 set transform-set ESP-3DES-MD5
crypto map 1925 set security-association lifetime seconds 86400
crypto map 1925 set nat-t-disable
crypto map 1925 set reverse-route
ansalaza Tue, 02/24/2009 - 14:07
  • Cisco Employee,
Sorry, the partial config does not help much...
Please try collecting these debugs from the local ASA:
debug aaa authentication
debug tacacs
Do you have connectivity (ping) from remote End to the Server behind the Local ASA?
Do you see any failed attempts on ACS?
ansalaza Tue, 02/24/2009 - 18:04
  • Cisco Employee,
It might be easier to check if
TACACS traffic is reaching the local Interface pointing to the ACS Server:
Step 1:
access-list captured permit tcp any any eq 49
Step 2:
capture tacacs access-list captured interface
is the Interface pointing to the ACS Server.
To see the information:
Option A:
show capture tacacs
Option B:
https:///admin/capture/tacacs
where is the IP address of your Cisco ASA's inside interface.
To remove the access-list:
clear configure access-list captured
To remove the Capture:
No capture tacacs
dbellamkonda Wed, 02/25/2009 - 06:28
Thnx much sir,
Will do that and let u know if i need any thing,.
Thnx again for ur time and help
