Need help with translation pattern
Feb 24th, 2009
I am trying to use a site code and 4 digit dialing to/from a new branch site.
I am using ccm 4.1.3
Gw's are h.323
So, example is x7777
I create a translation pattern 8.xxxx and discard the 8 and prefix 903900
(this is not working)
Then I create a route pattern 903900xxxx and point it to the branch router.
I also set up a dial peer 903900.... fwd 9 digits. I tested the dial peer and it works.
My problem is with the translation pattern.
Randall
Overall Rating: 3 (1 ratings)
Jaime Valencia Tue, 02/24/2009 - 14:29
  • Cisco Employee,
  • Hall of Fame,
    2011
are the calls making it to the dial-peer??
or are they being kept in CUCM??
if you dial what do you get??
the theory sounds correct, had you tried DNA to confirm the outcome??
you can also use the mask for called number 903900xxxx instead of using the prefix field, give it a try
java
if this helps, please rate
rcrumm_2 Tue, 02/24/2009 - 15:03
I used DNA right after i wrote this and found my problem.
Randall
