Unable to Delete ECC Variable
Answered Question
Feb 24th, 2009
I created an ECC variable and relized an alternate method in accomplishing my goal. I'm going back to clean up and trying to delete the ECC variable and it is erroring with "this variable is being referenced by a script".
I checked the script to make sure I didn't leave it by accident and was fine. I also resaved the script as a new version in the event that the variable was locked in shared memory. I also unchecked the Enabled box in config manager. No luck.
Anyone seen this problem before? Any suggestions?
Correct Answer by david.macias about 8 years 5 months ago
More than likely it's being used in an older version of the script. go to script explorer and delete the old version.
david
Overall Rating: 5 (1 ratings)
Correct Answer
david.macias Tue, 02/24/2009 - 15:10
  • Blue, 1500 points or more
david
eric_tanney Tue, 02/24/2009 - 15:20
That did the trick. Wow. That easy, huh? I guess I looked too deeply into it and missed the blatantly obvious.
Thanks!
-Eric
