No ring back/progress indicator on FXS ports
Feb 24th, 2009
Guys,
I am doing an install and I have fxs ports on the gateways for fax machines. However when I dial the fax number, I do not get a ring back. The fax rings but no ring back on the phone I am dialling from. This is affecting all the fxs ports.
any ideas.
sample config below
dial-peer voice 4780 pots
destination-pattern 4780
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 2/0/0
