Problems to validate CME 7.0 on CRS 5.0
Feb 24th, 2009
I have try to validate my CME on CRS, I have conectivity from both sides, I have already set te AXL user in CME.
I received the message "Unknown unified CME host name or IP address.Please provide a valid one."
in Unified CME Telephony Configuration option there is no session server ID asigned.
what could it be the problem?
Overall Rating: 5 (1 ratings)
ivillegas Mon, 03/02/2009 - 09:05
The CME User needs to be created under the telephony-service.
Following is the command:
telephony-service xml user USERID password PASSWORD 15
The last: 15 is necessary user privilege.
Are you using SIP provider for PSTN connectivity?
filiberto.aguirre Mon, 03/02/2009 - 13:49
Hi, thanks for your response.
In fact I had already set the user in telephony service
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
subscription maximum accept 5
registrar server expires max 600 min 60
voice register global
mode cme
source-address port 5060
max-dn 6
max-pool 6
authenticate register
timezone 9
date-format D/M/Y
file text
create profile sync 0834091551485358
sdspfarm units 5
sdspfarm transcode sessions 2
sdspfarm tag 1 MTP001b0cfb1fd9
sdspfarm tag 2 CFB001b0cfb1fd9
maximum bit-rate 256
xml user ccx5 password Citel2009 15
load 7902 CP7902080002SCCP051117A
load 7906 SCCP11.8-3-3S
load 7911 SCCP11.8-3-3S
load 7912 CP7912080003SCCP070409A
load 7920 cmterm_7920.4.0-03-02
load 7960-7940 P00308000500
load 7941 SCCP41.8-3-3S
load 7961 SCCP41.8-3-3S
load 7970 SCCP70.8-3-3S
load 7971 SCCP70.8-3-3S
load ata ATA030203SCCP051201A
max-ephones 48
max-dn 96
ip source-address port 2000
calling-number initiator
service phone videoCapability 1
timeouts interdigit 4
timeouts ringing 90
system message Telecomunicaciones
cnf-file location flash:
cnf-file perphone
user-locale ES
user-locale 1 ES
network-locale ES
I don't know what else could be the problem.
Maybe IOS?
I have c2800nm-adventerprisek9-mz.124-20.T.bin
I'm not using SIP trunk
vladimirstankov Thu, 07/02/2009 - 05:12
Hi Filiberto,
did you managed to solve this issue? I have the same problem trying to validate CME 7.1(IOS version 12.4(24)T) with UCCX 7.0(1).
The IP connectivity is ok from both sides. Also the AXL user is configured correctly. I'll appreciate if you can help.
filiberto.aguirre Thu, 07/02/2009 - 13:06
Hi vladimir,
In addition to the AXL user you must type the following commands
ixi transport http
response size 8
no shutdown
request outstanding 2
request timeout 30
ixi application cme
response timeout 30
no shutdown
after this you can go further with the installation.
mezcalito Wed, 07/29/2009 - 13:29
Remember to enable the http server on the router with the next command.
ip http server
I had the same connectivity issues till I used that command.
