janakamolagoda Tue, 02/24/2009 - 17:25
I too did the same.I hope it only support web applications such as OWA.you can use http(s)://IPADDRESSOFWEBSERVER/
eskriste80 Tue, 02/24/2009 - 17:29
I found the solution. To add local lan access you must do this:
access-list Local_Lan_Access remark Local Vpn Access
access-list Local_Lan_Access standard permit host 0.0.0.0
group-policy clientgroup attributes
split-tunnel-policy excludespecified
split-tunnel-network-list value Local_Lan_Access
tunnel-group sslgroup general-attributes
default-group-policy clientgroup
