dot1x - Computer Authentication not working
Feb 24th, 2009
Wired users.
When PC boots up and tries to perform "computer authentication" with ACS and then Win2003 AD, I get the following error:
"External DB user invalid or bad password"
ansalaza Tue, 02/24/2009 - 18:12
Check for the failed attempt does it display this format:
Check in the Auth.log for the same time range as in the Failed Attempt.
Is the computer part of the same domain as the ACS?
opers13 Tue, 02/24/2009 - 18:30
Yes, host/, and the PC is in the same domain
As ACS. ACS is a domain member not domain controller.
I have also added the computer account "CISCO" in AD.
Looking at the logs looks like communication issue with AD.
sahmedshahcsd Wed, 03/04/2009 - 03:54
Make sure the integration of AD and ACS is done perfectly.Verify the user authentication by using a valid user account from AD on any of the device such as Switch or Router.
Make a checklist of step wise procedure and be sure no single step was missed during integrating AD and ACS
