Turn off cisco 6500 bootup diagnostic will effect super-engine redunency ?
Feb 24th, 2009
I want to Turn off cisco 6500 bootup diagnostic to speed switch bootup.
But I am not sure whether it will effect super-engine redunency.
Have any one can help?
Yudong Wu Wed, 02/25/2009 - 20:35
  • Gold, 750 points or more
Bootup diagnostic is to test if there is any issue in hardware level. It should not impact redundancy. Only thing I could think about is that the standby sup might be bad and you don't know it since you turn off diagnostics. If you would like to boot the box up fast, you might change the diagnostic level to minimal.
