ACE: Problem configuring probe snmp
Feb 24th, 2009
I have a problem when I configure probe snmp and My Server W2K3 dual core, snmp comunity public has an oid cpu .1.3.6.1.2.1.25.3.3.1.2, the output is:
access-list anyone line 8 extended permit ip any any
probe snmp was
interval 4
faildetect 2
passdetect interval 10
receive 2
community public
oid .1.3.6.1.2.1.25.3.3.1.2
threshold 70
rserver host was1
ip address 10.24.8.200
probe was
inservice
rserver host was2
ip address 10.24.8.201
probe was
inservice
serverfarm host servers
rserver was1
inservice
rserver was2
inservice
class-map type management match-any ADM-CONTEX-SERV1
4 match protocol icmp any
5 match protocol snmp any
class-map type http loadbalance match-all Check-Headers
2 match http url .*
3 match http header Host header-value "10.24.16.*"
4 match http header User-Agent header-value ".*MSIE.*"
class-map match-all VIP-10-HTTP
2 match virtual-address 10.24.16.10 tcp eq www
class-map type http loadbalance match-all other-HTTP
2 match http url .*
policy-map type management first-match ADM-CTX-SERV1
class ADM-CONTEX-SERV1
permit
policy-map type loadbalance first-match L7-logic
class Check-Headers
serverfarm servers
class other-HTTP
serverfarm servers
policy-map type loadbalance first-match lb-logic
class class-default
serverfarm servers
policy-map multi-match client-vips
class VIP-10-HTTP
loadbalance vip inservice
loadbalance policy L7-logic
loadbalance vip icmp-reply active
interface vlan 60
ip address 10.24.8.5 255.255.255.0
access-group input anyone
access-group output anyone
service-policy input ADM-CTX-SERV1
no shutdown
interface vlan 233
ip address 10.24.16.5 255.255.255.0
service-policy input client-vips
no shutdown
ip route 0.0.0.0 0.0.0.0 10.24.16.1
sh probe was detail
probe : was
type : SNMP
state : ACTIVE
description :
port : 161 address : 0.0.0.0 addr type : TRANSPARENT
interval : 4 pass intvl : 10 pass count : 3
fail count: 2 recv timeout: 2
version : 1 community : public
oid string #1 : .1.3.6.1.2.1.25.3.3.1.2
type : PERCENTILE max value : 100
weight : 16000 threshold : 70
--------------------- probe results --------------------
probe association probed-address probes failed passed health
rserver : was1
10.24.8.201 13 13 0 FAILED
Socket state : CLOSED
No. Passed states : 0 No. Failed states : 1
No. Probes skipped : 0 Last status code : 0
No. Out of Sockets : 0 No. Internal error: 0
Last disconnect err : Server reply - bad SNMP OID
Last probe time : Tue Feb 24 23:22:41 2009
Last fail time : Tue Feb 24 23:20:47 2009
Last active time : Never
Server load : 16000
rserver : was2
10.24.8.200 12 12 0 FAILED
Last disconnect err : Server reply timeout (no reply)
Last probe time : Tue Feb 24 23:22:34 2009
Last fail time : Tue Feb 24 23:20:52 2009
Server load : 16000
Overall Rating: 5 (1 ratings)
ciscocsoc Wed, 02/25/2009 - 01:08
  • Silver, 250 points or more
For a multicore processor you need to make a few changes to get the load on each core/processor. You need to have an instance for each core.
Try adding .1 or .2 to the OID to get the load on each core.
Also try doing an snmpwalk on the OID to see what the real structure is.
Cathy
