Sup1A-2GE on 6509 with 3000 Watts Power Supply not powering on other Module
Feb 24th, 2009
I am having a SUP1A-2GE card installed on a 6509 chassis with 2 no of 3000 Watts Power Supply, but when i power it on, The Sup comes up but the Power Management Led starts to glow in Red and the other Modules WS-X6248-RJ-45 are not powering on.
I have attached the logs of the same.
Kindly help on this
Giuseppe Larosa Wed, 02/25/2009 - 01:49
Hello Ravi,
it looks like the module are not recognized or supported by this supervisor
Console> (enable) show module Mod Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC no ok
3 3 Unknown Card power-deny
4 4 Unknown Card power-deny
5 5 Unknown Card power-deny
9 9 Unknown Card power-deny
Hope to help
Leo Laohoo Fri, 02/27/2009 - 15:50
WS-X6248-RJ-45 is for the Sup2 engine (hence the "2" in the WS-Xn2nn-RJ-45). Is this a new purchase? If so, please contact your auhtorized Cisco reseller/vendor and see if you can come to an exchange agreement.
Hope this helps.
Bobby Thekkekandam Sat, 02/28/2009 - 11:13
It's not necessary to upgrade your supervisor to get this up and running. The problem is that the WS-CAC-3000W Power supply is not supported in 6.x CatOS software. The minimum CatOS to run this power supply is 7.5(1).
Your supervisor only has 64MB of DRAM, so while you can upgrade to 7.5(1), you can't go much higher than that. Check the DRAM requirements in the same document:
