Deny HTTPS "CONNECT" to ip-base url @ ASA/FWSM
Feb 24th, 2009
Dear All,
we are having problem as end users have a lot of spyware/walware and have illegal proxy install in the lan.
One of the idea is to deny HTTPS or "CONNECT" type http, at the "inside fwsm/asa" to any ip-base url destination. Since the ip-base url are random, maybe regex could help.
please advice us how to do it. thanks.
vikram_anumukonda Wed, 02/25/2009 - 03:57
Hi, could you explain what do you mean by an ip-base url ( does it mean users typing in the ip addresses in the browser instead of domain-name's. )
hasmurizal Wed, 02/25/2009 - 16:01
Hi Vikram,
yes, that's what i meant. (user's typing ip addresses instead of name addresses)
vikram_anumukonda Wed, 02/25/2009 - 21:17
you can try this
regex ipurl "\.[0-255]\.[0-255]\.[0-255]\.[0-255]"
class-map type regex match-any domain-list
match regex ipurl
class-map web
match port tcp eq www
policy-map type inspect http URL
parameters
match request header host regex class domain-list
drop-connection
policy-map global_policy
class web
inspect http URL
but if you are looking to filter https , you will have to go for a external url filtering server.
Hoping this is what you are looking for.
-vikram
hasmurizal Wed, 02/25/2009 - 21:39
nice...
class-map web
for this portion, can we replace www with 443 ?
vikram_anumukonda Wed, 02/25/2009 - 21:44
it wouldn't work if you replace "www" with "443" because the traffic is encrypted , for this very reason you will have to opt for an external URL filtering server.
I tried it once with 443 and it didn't work. You can give it a shot though.
Vikram
vikram_anumukonda Thu, 02/26/2009 - 01:42
the regex in my earlier reply is horribly wrong ,
will post a reply as soon as i have an accurate one
-Vikram
vikram_anumukonda Thu, 02/26/2009 - 02:57
the below regex will match anything but numbers in the host-header (http://<>/index.html - basically the address typed in by the user )
and the below code would drop the http connection as long as there is no a-z or A-Z in the host-header ( which is basically only numbers in the host-header )
regex ipurl "[a-zA-Z]+"
match regex ipurl
class-map web
parameters
match not request header host regex class domain-list
drop-connection
class web
inspect http URL
I really hope this is helpful to you.
-Vikram
hasmurizal Thu, 02/26/2009 - 04:07
hi.
thanks for the info. appreaciate the help that i received.
anyway, the real problem is due to this software which can bypass content filtering and firewall configuration. http://www.ultrareach.net/
on the content filtering server, we have manage it by applying deny "connect" regex ip addresses url. so i was thinking if there is anyway we can eliminate it on fwsm in case if the lan do not have content filtering servers.
i will check in the near future as i dont have any spare asa for now, and i will responce for any update later. thank you
