VPN partially working
Feb 25th, 2009
I'm trying to connect to my office network (which has a Cisco ASA 5505) with my Cisco VPN Client (v. 5.0.04.0300, XP SP3).
Although it works well from my home network (simple wifi with router), it is not as good from my university network.
From there I am able to establish a VPN connection successfully, but I can't access any remote network resources (ping, remote desktop, ...). This problem is the same whether I use Wifi or Ethernet.
Any ideas on how to solve this?
adamclarkuk_2 Wed, 02/25/2009 - 06:23
  • Silver, 250 points or more
It sounds like your uni environment is doing some filtering somewhere. I would ask the people who look after the network and see if they can help.
naveen_b81 Thu, 02/26/2009 - 23:19
Select the Connection entry for the VPN -> Modify -> Click on Transport -> Select IPSEC over TCP -> Leave the port number to 10000.
This should do the trick
