02-25-2009 03:10 AM
Hii Guys,
I need to know whether ..Is there any provison(IoS command) on Cisco Routers Or Switches to check the availability of total connected WAN Bandwidth.
For Example:- Suppose I have 26mbps of Bandwidth for WAN connectivity, And i need to cross-check & confirm whether really respective E-1s( for 26 Mbps) is commisioned or not.
Please share you views..how to check.
03-01-2009 11:02 PM
You can use 'ttcp', its an undocumented command:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094694.shtml
http://www.cisco.com/application/pdf/paws/10340/ttcp.pdf
Farrukh
03-01-2009 11:49 PM
Dear Farukh,
Is this command support on Cisco platform.
Also as i understand after reading the documents, We need to execute the command on both side of Network. But I want to check at customer side only i.e don't wanna involve parent node or ISP for this testing. Is there any provision.
03-01-2009 11:53 PM
For Internet you can employ any speed testing site like speedtest.net. But for WAN you need to run the TTCP command on both ends (routers or end hosts) to check properly.
Else you can download very large file (multiple files rather) and check using any bandwidth monitoring tool like PRTG etc.
Farrukh
