2811 not connected to the pbx with t1 trunk
Feb 25th, 2009
3640 gatwary was connected to the bpx with t1 trunk link.
after we changed from 3640 to 2811.
when we see command "show controller t1",
we saw "T1 0/0/0 is down"
configuration is same
what is problem?
[3640]
SHI#sh controllers t1
T1 1/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20000306, FPGA: 8
Framing is SF, Line Code is AMI, Clock Source is Line.
Data in current interval (21 seconds elapsed):
8799 Line Code Violations, 214 Path Code Violations
7 Slip Secs, 0 Fr Loss Secs, 21 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 21 Unavail Secs
Total Data (last 1 15 minute intervals):
363324 Line Code Violations, 11899 Path Code Violations,
459 Slip Secs, 0 Fr Loss Secs, 900 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
[2811]
Router#sh controllers t1
T1 0/1/0 is down.
No alarms detected.
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20071009, FPGA: 20, spm_count = 0
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (773 seconds elapsed):
6658099 Line Code Violations, 148773 Path Code Violations
56 Slip Secs, 0 Fr Loss Secs, 10 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 773 Unavail Secs
[2811 config]
controller T1 0/0/0
framing sf
linecode ami
ds0-group 0 timeslots 1-24 type e&m-wink-start
[3640 config]
controller T1 1/0
Paolo Bevilacqua Wed, 02/25/2009 - 10:37
Configure:
network-clock-participate wic 0
network-clock-select 1 t1 0/0/0
Also make sure PBX is providing clock.
If that not the case, remove clock select and configure clock source internal under controller T1.
yeundu Wed, 02/25/2009 - 15:52
[3640]
clock source is internal
[2811]
and
i configured "network-clock-participate wic 0"
is need config of "network-clock-select 1 t1 0/0/0" ?
Paolo Bevilacqua Wed, 02/25/2009 - 15:58
Not with clock internal.
The 3640 could be more tolerant regarding clock, it was expereincing many errors anyway, so try clock external, all failing check PBX settings again.
