Not enough DSP memory?
Feb 25th, 2009
We have now 12 channels but the problem is that we need 16 channels, but when I tried to configure it a message appears saying that we have no enough DSP memory. I tried to remove the ds0-group 0 to configure 16 timeslots but I can not. I have installed a PDVM32 but the problem is still the same...
This is the config in my router:
controller E1 3/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-12 type e&m-wink-start
description INTERCONNECT | 12 channels to PBX SIEMENS
Slot 3:
High Density Voice Port adapter
xxxx
HDV SIMMs: Product (FRU) Number: PVDM-12=
SIMM slot 0: PVDM-12 SIMM present.
SIMM slot 1: Empty.
SIMM slot 2: Empty.
SIMM slot 3: Empty.
SIMM slot 4: Empty.
And in:
Slot 0:
PVDM Slot 0:
32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8539-05
Board Revision : B0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC112312F5
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-32
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
PVDM Slot 1:
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC11441V4X
RMA History : 00
Processor type : 00
Overall Rating: 5 (1 ratings)
Hythim Ali El Hadad Wed, 02/25/2009 - 04:28
Hi Hernan,
It is shown from your information that you have PVDM 12 installed and you have i HDV-NM
which have 5 PVDM-SIMM sockets
each pvdm-12 give you the folloiwng:
Runs up to twelve voice calls using a medium complexity CODEC (G.711, G.729a/b, G.726, fax).
Runs up to six voice calls using a high complexity CODEC (G.729, G.728, G.723.1).
And you have only one pvdm-12 installed
Check to see if your router support the 2 PVDM2-32 installed and if you configured them as MTP or conf resources
hernanseijas Wed, 02/25/2009 - 05:34
Thanks for your answer and sorry for my ignorance...but where can I check how to do this configuration?
regards
Nicholas Matthews Wed, 02/25/2009 - 05:37
Hi Hernan,
If you move the T1 card to one of the HWIC slots on the chassis instead of the NM-HDV card, this will work because you have 2 PVDM2-32s on the motherboard. The NM-HDV only has capability for 12 channels at the moment.
hth,
nick
hernanseijas Wed, 02/25/2009 - 06:08
Thanks for your answer, I have this router:
Slot 0:
C3845 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapter, 5 ports
PVDM Slot 0:
PCB Serial Number : PVDM2-32
PVDM Slot 1:
FOC11441V4X
WIC Slot 0:
Serial 1T WAN daughter card
Hardware revision 1.0 Board revision J0
Serial number 23614000 WIC-1T=
RMA number 00-00-00
Connector type Wan Module
EEPROM format version 1
WIC Slot 1:
Serial number 22168867 Part number 800-01514-01
FRU Part Number WIC-1T=
Test history 0x0 RMA number 00-00-00
Slot 1:
NM-2FE2W Port adapter, 2 ports
Port adapter is analyzed
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 8
NM-2FE2W=
WIC Slot 0:
WIC-1T=
Wan Module
Slot 2:
Mueslix-4T Port adapter, 4 ports
Board revision H0
Serial number 22689719 Part number 800-02314-02
FRU Part Number NM-4T=
Slot 3:
Port adapter insertion time unknown
Hardware Revision : 1.1
Top Assy. Part Number : NM-HDV=
SIMM slot 1: Empty.
SIMM slot 2: Empty.
SIMM slot 3: Empty.
SIMM slot 4: Empty.
WIC Slot 0:
E1 (1 Port) Multi-Flex Trunk WAN Daughter Card
Hardware revision 1.0 Board revision B0
Serial number 28201726 Part number 800-04475-03
FRU Part Number VWIC-1MFT-E1=
Test history 0x0
HDV firmware: Compiled Fri 19-Nov-04 14:23 by michen
HDV memory size 524280 heap free 193977
Slot 4:
NM-2FE2W_V2 Port adapter, 2 ports
Top Assy. Part Number : NM-2FE2W-V2
WIC Slot 0:
E1 (2 port) Multi-Flex Trunk WAN daughter card
Serial number 34969306 Part number 800-04479-04
FRU Part Number VWIC-2MFT-E1=
Connector type PCI
WIC Slot 1:
Serial number 34969258 Part number 800-04479-04
Test history
Can I do the change you are saying?
Nicholas Matthews Wed, 02/25/2009 - 06:42
It looks like you have 2 WIC-T cards on in the HWIC slots, and there are 4 on the 3845. You should be able to move the card.
-nick
