ASDM Login
Answered Question
Feb 25th, 2009
Dear All
We are having an ASA 5510 in routed mode.Now I can telnet the ASA.But when I log on by Cisco ASDM launcher and try to check the configuration, it is saying"ASDM is unabale to load the configuarion ,please check your configuration and connectivity".Please advice ..
Correct Answer by arvind.thevendr... about 8 years 4 weeks ago
In ASDM, clear ASDM cache and internal log buffer (nothing to do with firewall config or logs) and then select refresh ASDM with the running configuration on the device option. all these options are there in the file menu of ASDM.
This will help you to run ASDM in all the JAVA versions. You might not want to change the JAVA version just for one application, other apps may want to use the latest one.
If you still face issues,
1) Find the asdm-launcher.config file (C:\Program Files\Cisco Systems\ASDM\asdm-launcher.config)
2) Right click, choose properties and remove the 'read only' check
3) Open the file and add the following line:
javapath c:\Program Files\Java\jre1.6.0_07\bin\client\jvm.dll
4) Save the file and replace the read only check
Kindly let me know if this works for you.
Overall Rating: 5 (1 ratings)
arvind.thevendr... Wed, 02/25/2009 - 05:19
Can you post the exact error. It may issue with your JAVA. Is it opening in your browser.
If not opening, issue the command
http server enable
http inside
if still issues, can you check the IOS and asdm version.
soumik1979 Wed, 02/25/2009 - 22:11
Cisco Adaptive Security Appliance Software Version 7.0(4)
Device Manager Version 5.0(4)
Cisco ASDM launcher V.1.2(1)
Giving all the version details
Leo Laohoo Thu, 02/26/2009 - 14:25
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Do you have a firewall application installed in your host machine? What browser are you using? What is the Java version?
Correct Answer
arvind.thevendr... Fri, 02/27/2009 - 12:42
soumik1979 Fri, 02/27/2009 - 19:45
Problem solved .This works.Now I can see the configurations and check everything.Thank you for the solution...
soumik1979 Fri, 02/27/2009 - 23:36
Arvind now everything is fine as per your solution. Thank you for your responce..
