How can I upload an IOS from computer??
Feb 25th, 2009
Ok, here is a dumb question....
I am used to using a TFTP server to upload files to my switches... However, for this particular switch for testing purposes, HOW CAN I UPLOAD A IOS FROM THE CONSOLE COMPUTER ITS CONNECTED TO??
Any help would be appreciated!!!
glen.grant Wed, 02/25/2009 - 05:09
From the console you would have to use the xmodem method . Easier and faster method would be to give your pc an address in the space of the mgt. ip of the switch and make sure you have a tftpserver app running on your pc and then just do a normal copy tftp flash or bootflash command . Free tftpserver apps are available from places like solarwinds and another is tftpd32 .
Joseph W. Doherty Wed, 02/25/2009 - 09:56
BTW: Console serial uploads are much, much slower than typical LAN loads. Many Cisco devices support higher bps than the common 9600 default and file transfer protocols faster than basic Xmodem. Using one or both can very much increase the speed of a console upload (although still slow compared to typical LAN loads).
cisco_himg Wed, 02/25/2009 - 10:08
Here is what i did....
I had two catalyst 3750 switches....
I connected their stackwise cables together and provisioned the second switch.
Ofcourse the software version didnt match..
I just ran the config- Archive copy-sw /destination-system 2 /overwrite /force-reload 1
it took the IOS from switch one, and copied it to switch two and reloaded only the second switch...
IT WORKS!...
THanks for your help!
