ITS Pantel doorphone with FXS disconnects after pickup
Feb 25th, 2009
I've got a 2811 with a VIC2-2FXS card. 1 port is connected to a ITS Pantel 1 button doorphone.
The doorphone is programmed to dial a 4 digit extension.
The router has a voip dialpeer to point to the callmanager (version 7).
The ipphone rings but as soon as the call is answered, the call is disconnected.
If I connect a normal analog line to the same FXS port, and dial the 4 digit extension everything is working fine.
An incoming call to the doorphone is also working fine. The doorphone automatically picks up
and the call is established.
When I use a ATA, all is working fine as well.
Any idea on how to solve this? WHich debug commands can I run to try and determine the cause?
Thanks in advance,
Jeroen
Nicholas Matthews Wed, 02/25/2009 - 05:18
  • Red, 2250 points or more
Hi Jeroen,
There are a few things to try:
1) Maybe it's a DTMF issue. Try configuring a PLAR CSS/partition for the number the phone is programmed for, and let the DTMF digits do nothing.
2) Maybe the phone doesn't like something the router is sending. Try 'no caller-id enable' and 'no battery-reversal' and shut/no shut the port.
hth,
nick
jeroenhermans Wed, 02/25/2009 - 05:23
Thanks for your fast reply.
I have tried connection plar with my 4 digit number and removed the programming on the doorphone so it is not sending anything. The exact same thing is happening then. -> the ipphone rings, but call is disconnected if I pick up.
I will give your option 2 a try and let you know the result.
Jeroen
jeroenhermans Mon, 03/16/2009 - 07:27
I finally got round to testing option 2, it is giving the exact same issue.
ANy other ideas?
Jeroen
Nicholas Matthews Mon, 03/16/2009 - 08:30
If you've confirmed that it's not DTMF or battery reversal/caller-id, you may want to open a tac case on this.
Very hard to say by speculation.
-nick
jeroenhermans Tue, 03/17/2009 - 06:01
If I configure the port via mgcp (POTS), the first call does not disconnect. The second call I try just gives me dial tone, but nothing happens.
It is only when I configure it via h323 that I have the disconnect issue.
How can I configure the port via h323 so that it has the same config it would have as when I use mgcp?
Jeroen
jeroenhermans Sat, 03/21/2009 - 09:08
I managed to resolve the issue by adding the command no battery-reversal to the voice-port
Kind Regards,
Jeroen
Nicholas Matthews Sat, 03/21/2009 - 19:33
Hi Jeroen,
Excellent! There are tons of issues solved by turning that command off. Glad I could help.
-nick
