eigrp neighbor flapping
Feb 25th, 2009
Hello all,
i am facing one acute eigrp problem , getting error as below ,
%DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.140.10.1 (Vlan10) is down: retry limit exceeded.
Could any one solve my problem.
MR
Overall Rating: 4 (1 ratings)
maahiraahi Wed, 02/25/2009 - 06:50
conf on 10.140.10.2
interface Vlan10
ip address 10.40.10.2 255.255.255.0
ip helper-address 10.40.10.9
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
ip cgmp
no ip mroute-cache
load-interval 60
standby 2 ip 10.140.10.3
standby 2 priority 105
standby 2 preempt
arp timeout 28800
router eigrp 100
redistribute connected
redistribute static
network 10.0.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.140.10.1
conf on 10.140.10.1
#sh run int g0/0
Building configuration...
Current configuration : 248 bytes
interface GigabitEthernet0/0
ip address 10.140.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
media-type rj45
service-policy input Cos_in
end
router eigrp 100
redistribute static
redistribute bgp 65000
network 10.0.0.0
default-metric 2000 10000 255 1 1500
no auto-summary
no eigrp log-neighbor-changes
maahiraahi Wed, 02/25/2009 - 07:13
10.140.10.1 - its a router running bgp for WAN and eigrp for lan.
101.40.10.2 - its a L3 sw , running EIGRP for lan.
both are directly connected.
neighbour flaps every 1min 20 sec.
eeded
%DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.140.10.1 (Vlan10) is up: new adjacency
think this will help u out.
lamav Wed, 02/25/2009 - 09:55
  • Blue, 1500 points or more
Hi:
Under vlan 10's SVI, I see you have 10.40.10.2 and the neighbor is supposed to be 10.140.10.1. Is that a typo under the vlan 10 interface?
Also, I see that you have a QoS policy applied to the neighbor interface, are you sure that the eigrp hellos are not being dropped to allow higher prority traffic to use that link?
You may want to isolate the problem to either a network issue or a higher layer problem with the hellos themselves. If it fails every 120 seconds, can you run an extended PING between routers to see if it fails?
DialerString_2 Wed, 02/25/2009 - 14:47
  • Bronze, 100 points or more
If you hello timer are different your adj will flap. Try hardcoding them on both sides. Check your cables if you haven't already
maahiraahi Wed, 02/25/2009 - 20:36
Ping response is ok from router to switch. mtu is 1500 on both the side.
maahiraahi Wed, 02/25/2009 - 20:42
observing SRTT 0, Any clues?
#SH IP EIGRP INTerfaces G0/0
IP-EIGRP interfaces for process 100
Xmit Queue Mean Pacing Time Multicast Pending
Interface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes
Gi0/0 2 0/0 0 0/1 50 0
You said it started to do this 2 days ago - but before this everything was OK.
So what changed 2 days ago - EIGRP after being configured and forms a good neighbour does not suddenly stop working unless something has changed, either in config or physical or connectivity.
Check the logs to see what happend the time it started to flap.
maahiraahi Sat, 02/28/2009 - 03:33
veriried, But didnt get any clue.
Then suspected Lan cable as it was about 50m long. chanbged it,then its started working fine.
looks strange, as i didn't see any packet drops on the interfaces , mtu fine, ping response was fine .
Lost option was to change the cable.
any way thanks every one.
Anil.
