Webview reports
Feb 25th, 2009
I have a user that is trying to schedule reports in webview and have them to automatically print to the network printer. the problem is we received an error about her not being an administrator on her machine. My question is there a way around scheduling her report to print without making her an administrator onto her local machine?
BTW..the webview server is not on the domain there for it cannot connect to this printer.
joesnyde Wed, 02/25/2009 - 06:56
  • Cisco Employee,
Hi Linda
The install guide page 11-15 goes over the requirements for schedule reports to run sucessfully. I have included the 7.0 version for reference
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/enterprise_reporting/reporting7_0/installation/guide/wv75insg.pdf
It does not mention that a user has to be a local admin on the box. However a minimuum Local rights need to be configured per the documentation.
Why is the Webview server not on the domain? Is this server seperate from the AW?
Joe
kre8or2007 Wed, 02/25/2009 - 09:05
I have this working on our installation anyway, the report actually prints from the PC, so it probably saves it somewhere temporarily. does the user have rights to save this file? I am assuming the user has rights to print.
lkinchen Wed, 02/25/2009 - 09:14
yes you are correct. the user does have access to print. I have to get management approval to give her access to the local security policies as stated in the document you sent to me. btw..great information.
lkinchen Wed, 02/25/2009 - 12:26
I followed the instructions on the document and the user is still receiving the same error about not having admin privileges. any other suggestions.
joesnyde Wed, 02/25/2009 - 13:00
  • Cisco Employee,
Linda
Did some more digging and found that it may be necessary for the user to have admin rights on the local machine, see Bug ID CSCgt08958. Not sure what version you are and this bug is an enhancement. I do know in older versions, before ICM7, that it was required to be a local admin and it was documented. See beginning of Chapter 5
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/enterprise_reporting/reporting5_0/user/guide/WebView_User_Guide_50.pdf
If policy dictates that the user is not to have local admin rights you may have your hands full. Check what the BU stated
"Because of the privileged nature of Job Scheduler, in order to use it the logged in user must be a member of the local administrators group. However, I believe that Deny security rights take precedence over Allow in Windows. You could create a local group for WebView
users (e.g. LocalWebViewUsers) and add the user to that group. Note that the user that you add to the group is the username that is logged into Windows, not the one logged into WebView. You could then add the LocalWebViewUsers group to the Local Administrators
group. After that, you could explicitly deny the LocalWebViewUsers group access to any files and folders that the customers feel that webview users shouldn't have access to. We don't currently have a formal description of which files/folders/programs that the
LocalWebViewUsers group needs access to, so you should probably start by adding the LocalWebViewUsers group to the administrative group, make sure that job scheduler works, and then steadily lock down the system, checking after each iterative lock down that Job
Scheduler still works. Hopefully we will have a formal document describing what must be left open in the near future" NONE THAT I COULD FIND
And
"The main reason that job scheduler requires local admin membership is because the file thescheduler.dll, which is used to create the scheduled job, uses the Windows Network Management library function NetScheduleJobAdd(). The security permissions of this
function require that the user be in the local administrators group. If they need job scheduler to work without requiring local administrator privileges, then they will need to
file an enhancement request. Note: This is not a bug. This is the way that the product was designed and the way that it is correctly documented to work."
Joe
