NAT question
Feb 25th, 2009
will the following NAT config on an ASA conflict?
First part is for one to one NAT for inside address
static (inside,outside) netmask
access-list outside_in permit tcp host host
following is an exception for the one to one NAT. I have a host on the outside that needs to access the inside host, but they cannot use as the destination. So here was what I proposed:
access-list nat-exception permit ip host host 209.x.x.x
access-list outside_in permit tcp host 209.x.x.x host
basically I have a static NAT already in place, but have a new customer coming in that needs to access the same internal address via an address that is not the already defined static statement so I was wondering if the static with the access-list would be a workaround without conflicting with or affecting the one to one NAT? I'm guessing the one to one NAT trumps my idea. If anyone has any idea on how I can make this work please advise. Thanks
allen.malanda_2 Wed, 02/25/2009 - 07:49
I had the same type of issue. I had to use policy nat to fix it. The policy nat is triggered by access-list. Your second nat command is a policy nat. You should convert your one to one nat to a policy nat. You may still see a nat conflict pop on your CLI. But it will still work fine.
